What is ASTM 620 Material
I have a drawing of that calls out the following material. Can someone explain to me in English what this material is?
In German:
Din En 10139 - OC04 + LC - MA - RM
Beschichlung: Din 50962 - Fe/ZnFe 0.5-3 A
Disp
In English:
ASTM: A620; JIS G3141 SPCEN
Coating Din 50962 - Fe/ZnFe 0.5 - 3 A
Disp
This material is for a part called a magnet yoke and it looks like a bushing.
In German:
Disp
In English:
Disp
RE: What is ASTM 620 Material
Standard Specification for
Drawing Steel (DS), Sheet, Carbon, Cold-Rolled
Obtain a copy of the above to review it
http://www.astm.org/Standards/A620.htm
DIN 50962 specifies zinc and zinc alloy coatings, with the Fe/ZnFe designation indicating a zinc-iron coating. The 0.5-3 indicates that the mass % of iron in the coating is 0.5-3%. There should be another numeral to indicate the coating thickness in μm, e.g. 5, 8, or 12.
Also, while ASTM A620 used to be the correct North American equivalent to DIN EN 10139, it has been superceded by ASTM A1008/A1008M. The grade is called DS Type A or DS Type B.
Billy
