Plug valve actuator
Plug valve actuator
Can a large plug valve (42 inch) buried 3ft below grade be controlled using an above grade Pneumatic actuator?
RE: Plug valve actuator
Has anyone eeperience of...?
Is there a mnaufacturer of...?
Is it costly to ...?
I would suggest that a hydraulic or electric operator may be a better solution. However if you only have air then a pneumatic to hydraulic device is available to provide a small actuator.
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
valve torque requirements, normal, max, min, breakaway, all valve dimensional data, and rotation data - get from valve mfg.
forward all valve data, i.e. torque requirements, energy sources available, limit switches, instrumentation requirements, etc. and dimensional data for mounting actuator, to a supplier of actuators and then you can get your answer.
as stanier alludes to, actuator size & cost is dependent upon actuator type selected.
good luck!
-pmover
in general, the higher the power gas pressure then the lower the cost of the actuator. that is why stanier suggested a hydraulic type actuator.
there are companies who make a skid mounted, mini central hydraulic system to go with the hydraulic actuator.
you will also have to have a high head extension to get the actuator above grade.
After reading all the comments I realize that electric or hydraulic type actuators are also possible. I will contact Rotorak to obtain more details
Only put off until tomorrow what you are willing to die having left undone. - Pablo Picasso
