Displaying all parts in assembly as RESOLVED
Hi we are trying to upgrade our graphics cards
To help choose best one we are analyzing # triangles in typical models
The macro only works if all the parts in your assem are resolved.
Thus the reason for my question.
I have a medium size model would like to resolve every part in it,
2013 parts, 237 subassemblies, 6 levels, do not want to go through every part one by one and resolve.
Before I open the model i go to System Options -> Performance and UNCHECK "Automatically load components lightweight".  And I leave checked "Always resolve sub-assemblies". and for "Check ..." I put "Always Resolve" and for "Resolve lightweight components" I put "Always" and for "REbuild assembly on load" I put "Always".
When I open the assembly it will ONLY open in "Large Assembly Mode". If I go Tools-> then unselect "Large Assembly Mode", the save the assembly, then close it, then reopen it, the "Large Assembly Mode" icon is once again $%#@@$^*@ checked.
Also, opening and closing the assembly AUTOMATICALLY CHANGES the selection in system options -> performance and RECHECKS the box "Automatically load components lightweight" !!?? WHY????!!! I just unchecked that box, and did nothing to indicated I want it rechecked!
So basically I would like to know two things:  How the &% to get out of "large assembly mode" and how the *# to get ALL THE PARTS in the assembly, all at once, to be RESOLVED.
I haven't found the SW "help" to be useful on this subject.
THanks!!!
RE: Displaying all parts in assembly as RESOLVED
Go to tools/options/assemblies and dial the number in large assembly mode up as high as you want it.  Also, if you right-click at the top of your feature manager you can select Set Lightweight to Resolved.
Dan
www.eltronresearch.com
Dan's Blog
Ah, thanks - that's easy.  I'd selected all the top level parts and assemblies and tried "set lightweight to resolved" and for some reason that didn't work - but your way did.  thx again.
