Remove a part from a part family
How do you remove a part from a part family?
If the line from excel is removed, and the reference is cut from Teamcenter is there another step to remove references?
RE: Remove a part from a part family
Not sure you can remove the references in TC.
There is also the physical file of that instance on disk/in TC to be removed, if you can.
Why do you need to do this?
Ben Loosli
Thank you...
Using NX 8 and TC8.3
