ASME Flange Rigidity check is applicable for rectangular flanges?
Is the flange rigidity check of para 2-14 of ASME VIII div.1 appendix 2 applicable also for the rectangular flanges? (My question regards the cover plate of an aircooler heat exchanger header)
Someone can help me?
RE: ASME Flange Rigidity check is applicable for rectangular flanges?
Why not design your cover to UG-34?
Mike
but I would like to know if I have to perform also the check of rigidity according to 2-14, considering that Appendix 2 is mandatory, what do you think about?
Of course, you are free to do any calculation you wish. Regarding the rigidity calculation, how confident are you that such quantities as the constants and rigidity factors etc are the proper values for rectangular flanges? Is it just a "numbers in, numbers out" kind of calculation?
Mike
regarding the previous matter, I did some additional check.
The design of the cover can be made using UG-34,
but UG-34 does not give information about the design of the flange to which the cover is bolted.
So in my opinion the rectangular flange welded to the header shall be designed using appendix 2 (see 2-1 (d)). Conseguently also rigidity check of 2-14 shall be performed.
Moreover all the parameters in the formulas of rigidity factors can be easily applied to rectangular flanges.
Everyone's opinion is welcome.
regards
See 14-4(i). Flanges designed per U-2(g). Appendix 2 is for circular flanges only, see 2-1(a) regarding "circle". We design rectangular flanges per U-2(g) following guidelines from the book "Design of Process Equipment" by Kanti K. Mahajan. Air cooled heat exchangers Part C-Coverplate and flange design for header box. We have never had an issue with the AI or the Customer in doing so. In my opinion a flange rigidity check per Appendix 2 is not required.
