ABB CAP 505 installing problem
Hi
I cannot install ABB CAP505 software on Windows 7.
Problem may be related to MicroSCADA account problem.
how can I overcome this problem?
thanks
RE: ABB CAP 505 installing problem
It works with XP and not on Windows 7.
Thanks Inpran, I have the same problem. Are you saying there is no solution to this?
Erni,
As JG2828 said the software works on xp only. If you have windows XP mode, it will work all fine if the integration between XP and 7 is established properly.
