Pipe sleeves at Road crossing
Pipe sleeve made up of carbon steel pipe, 30" diameter with 3/4" thickness is to be installed in a road crossing which is 6.0 meters wide. This pipe sleeve is supported with 6-8" diameter steel piles driven 8.0 meters depth spaced equally. My question? Is the pipe support really required for road crossing since the pipe sleeve is directly supported by the soil. I believe this is over design.
RE: Pipe sleeves at Road crossing
your pipe casing should support all loads without piles
This sounds like a quite special design (am curious what is soil etc. strata and supporting strength below prospective casing?)
This has the feel that a LOT more information is required before your question can be dealt with. There have been a few occasions that I have supported buried utilities, none of them were simple.
Info required is not limited to:
What is the soil profile? with specific Geotechnical info.
Who recommended the pipe support?
Does the area have a history?
If the soil is so dodgy to need piles for the casing I would be considering horizontal direction drilling the main pipe and avoid the challenge.
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
this is a road crossing. presumably the road has already been stabilized sufficiently to handle traffic loads without settlement. the additional load of a pipe on the subgrade is relatively small and should not cause additional settlement over and above what might be caused by traffic load. The carrier pipe is also inside a casing. So traffic loads would not bear on the carrier pipe. I would want to see a clear need for the piles and for the casing otherwise this smells like over design as suggested by the OP.
Also, if the road settles, as it usually will, you will get a hump in the road as the casing does not settle.
