Taj Mahal foundations deteriorating
Article on the Taj Mahal. Wood foundations starting to become embrittled due to falling water table.
Link to Taj Mahal article
RE: Taj Mahal foundations deteriorating
The existing Taj is a monument to symmetry, with identical semi-precious gems ground in pair were adhered to the marble on opposite ends of the faces of the structure. The exceptions are minor, like the width of the inlays increasing slightly from bottom to top.
A major variation (I did not measure) is the tilt of the minarets or towers that tilt out very slightly, so if there was a collapse/failure, the tower should fall away from the central portion and not on the tombs or crypts. An eventual collapse was anticipated.
Because of the age, the details make sense, but the physical design and details are not available.
I am just an engineer with a lot of international travel and not a tourist, but this building is amazing and unique and it is head and shoulders above others I have seen.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
