Help with European Power Symbol
Could anyone help me identify a European electrical symbol in the attachment. The AC of the generators is passed through a drive to a DC bus. The DC bus then feeds another drive to an AC motor. What is the symbol between the drives and the DC bus? The DC bus was drawn up by perhaps Dutch or Finnish engineers.
I thought the two vertical lines with a square around it might represent some sort of power capacitor but I'm just guessing.
Thanks for your help in advance!
RE: Help with European Power Symbol
But I also found something similar on another website that said it was specific to "drives" that shows a box with a single cross inside and lists the description as "Switch mechanism with mechanical release " with an IEC designation of 102-05-04. But further investigation of that IEC reference number comes up with a footnote that says "Not yet defined".
Given the context I would guess it is two fuses as well, that's a fairly common application for common DC bus drive systems like that.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
jraef, thanks so much for the fabulous link. I googled your other information and came across this Moeller wiring diagram booklet (probably what you saw?), specifically pages 9-21 through 9-32 that was also good info.
http
