Design of Annular Piston - Length to Diameter Ratio
Need criteria for selection of piston length for an annular piston design. The ID is 10 inches and the maximum operating pressure is 7500 PSI. Plan on using PolyPac Seal system, but cannot find a reliable criteria for L/D ratio/piston anti-jam stability. Operation is subsea in 5000 to 10000 feet of water.
RE: Design of Annular Piston - Length to Diameter Ratio
Ted
