Constrain an object to another
I would like to constrain a round "tooling ball" to the surface of a block. Is there an easy way to do this, do both components need to be in an assembly and use assembly constraints? If so, what is the procedure to do this? Any advice would be appreciated thank you.
RE: Constrain an object to another
This forum is dead, have you tried posting on the Kubotek webforum? Lots of users there. You don't need to be current on maintenance to post, just a legal user.
Most of the content can be accesses without a customer number.
If that doesn't help, there is also a linked-in and Facebook page for KeyCreator. The links are located on the header of the website page for Kubotek USA: http://www.kubotekusa.com/
They also have a phone number for support there 800-372-3872.
I hope that helps.
Scott
