Bearing Capacity - Rock
I am designing a foundation on rock with a UCS = 50 MPa.
The RQD is about 55% and RMR is about 30. When I refer to Bienawski Table for Rock Classification it gives:
C = 150 kPa
Phi = 20 deg
for the rock mass.  These give an allowable bearing capacity of 200 kPa.
When I refer to Goodman Rock Mechanics book, it suggests:
C = 0.25 (UCS) = 12.5 MPa
phi = 30 deg
for the rock mass.  These give an allowable bearing capacity of 5000 kPa.
I cannot understand why the results are so much different.
It would be appreciated if you let me know where is the problem.  Thank you.
RE: Bearing Capacity - Rock
Corrections:
C = 150 kPa
Phi = 20 deg
for the rock mass.  These give an allowable bearing capacity of 1100 kPa.
phi = 30 deg
for the rock mass.  These give an allowable bearing capacity of 2500 kPa.
Check out Tomlinson's Foundation Design and Construction book - good presentation.  Rock is sometimes a very strange bedfellow for something one thinks is cake.
