AWS PQR testing
AWS PQR testing
Can A514, TP100 and Domex be groped together for PQR testing?
RE: AWS PQR testing
Or hire a Welding Engineer.
RE: AWS PQR testing
RE: AWS PQR testing
Specification for Welding Procedure and Performance
Qualification. This specification provides material group numbers and list of base materials.
RE: AWS PQR testing
RE: AWS PQR testing
As Mr168 points out, most clients consider themselves 'The Engineer' and will not accept the clause in the code, probably due to ignorance. But worth checking first to get your ducks in a row for a substantiated debate, which probably will not go your way. Good luck!
