material for sleeve bearing anti-rotation pins (insulated)
I believe NEMA G-11 is a common standard material (which has insulating properties and relatively good strength) used for sleeve bearing anti-rotation pins (in motors where the bearing is insulated from its housing).
Is anyone aware of stronger materials for this sleeve bearing anti-rotation pins, or perhaps the feasibility of inserting a thinner-diameter steel pin inside a hollow (drilled out) G-11 pin?
(2B)+(2B)'  ?
