extrude cutting into a curved surface created by an extrude cut
hello all!
So here's my problem.. I extruded a shape on one axis, and trimmed it on the other axis to the right profile. Now I want to cut a hole into the rounded back face.. or shell from that face.. but neither work. I even tried a lofted cut.. it comes out with errors like 'feature cannot cut that body' or 'the cut does not intersect with the body so can't cut'.. even though it clearly is.. does solidworks have issues making complex cuts into a spline-created rounded face?
RE: extrude cutting into a curved surface created by an extrude cut
Thanks@!
Dan
www.eltronresearch.com
Dan's Blog
Dan
Dan's Blog
Take a look at the attached file for an alternate & simpler method.
