FFT and IFFT of PSD acceleration and stress
given a test request which specifies a random vibration profile as a PSD and after running a simulation to get a PSD stress, is it possible to simply carry out inverse fft of the responce (nm^2)^2/Hz to get the stress in the time domain (nm^2/s) and then carry out rainflow counting to estimate fatigue?
The simulation uses modal and linear dynamics to get PSD repsonse.
thanks in advance
thanks in advance
RE: FFT and IFFT of PSD acceleration and stress
Cheers
Greg Locock
Fe
im not questioning your responces, just desporatly trying to clarify what is essentially a complex subject that i for one have been going in circles with.
when you form the psd, the phase information is lost
now you can make assumptions about the system response and construct a phase response per your reference, then reconstruct the time series from the data, but it is no longer the actual data but a guestimate...
I suggest that you re-read page 3, which explains exactly what the author meant.
TTFN
Chinese prisoner wins Nobel Peace Prize
