Assembly constraints?? Why so difficult?
Any clues how to quickly figure this out because we are about to ditch trying to constrain parts. I was off a few months and come back to be forced to use assembly constraints and boy does it suck. I have spent about an hour trying to correctly position sheet metal parts with odd angles and it will turn it everyway but the way I want. If I align to one side it flips it upside down , if I try to use distance then it moves into space. I just don't understand how and why it has gotten so difficult. I would think I could align a couple faces and call it done. We are concluding it is not worth the time wasted trying to constrain while production is waiting for the parts to build protypes. What a shame that the tool is too difficult to use, smaller companies cannot afford the expensive training and the documentation is difficult to decifer. Probabaly user error but after 15 years on UG i would think I am at the very least average in ability why would you create a program that the average user can waste hours trying to figure out. I see solid works coming in our near future.
RE: Assembly constraints?? Why so difficult?
Once you understand how it works, it's really not that hard.
If something flips upside down it's probably because you gave it the wrong constraint. Don't forget that there's a button to get the alternative option of a constraint.
Although I do have to agree on the distance one. It has happened to me as well. Quick solution is to first measure the distance between 2 parts before you apply the distance constraint.
NX 7.5
Teamcenter 8
