[NX7] Selection all part family member in assembly
as in the object, without 'Advanced Assembly' license, how can I perform this operation ?
The reason is I want switch all part family member from one reference set to 'Model' reference set.
Thank you...
Using NX 8 and TC8.3
RE: [NX7] Selection all part family member in assembly
Add the reference set column to your assembly navigator if it is not already there, order the navigator by reference set, group select those with the wrong reference set, right click and replace ref set with the one you want.
I'm not sure that family member parts need some special selection technique.
