Flexible pipe roughness
Hello everyone,
How can I compute approximately the flexible pipe head loss?
I read in this forum that I should be using a roughness of ID(mm)/250 but how can I use this to have the pressure drop.
thank you
thank you
RE: Flexible pipe roughness
http:
However, for me, the issue is that you use a ID-dependent absolute roughness that begets a ID-independent relative roughness since in Moody diagram, we use the e/D relative roughness.
For example,
You have a flexible pipe with ID=8"
The absolute roughness is e=ID/250
To use Moody you will have to get the relative roughness defined by e/D with D=ID so the relative roughness is 1/250 whatever the inner diameter of the flexible pipe ...
You could say that in this theory a pipe with ID=6" is equivalent to a pipe with 8" etc..
The danger here is that you could underestimate the pressure drop and find yourself with an undersized pipe...
e = absolute hose roughness
D = ID
Like I said and like you said, the relative roughness pipe is e/D with e = absolute roughness (in the case of flexible pipe it's apparently ID/250 see: Mark62 http://www
and d=ID
so relative roughness is equal to (ID/250)/ID = 1/250 which means that whatever the ID , darcy friction factor is independent of your geometry...
I find it surprising, that's all .
I'm not asking about calculating pressure drop in general but only about the relevance of this formula (e=ID/250) !!
absolute roughness = 1/250 = 0.004
then,
rel roughness = 0.004 / ID
but I'm guessing there.
Only put off until tomorrow what you are willing to die having left undone. - Pablo Picasso
What do you mean by i-one ? ID-1?
To ione thanks for your answer, I guess now you understand what my problem is... I am in front of a formula that I must use while I know it's irrelevant.
Maybe someone could enlighten me on how Pressure drop is assessed in a flexible pipe like NKT's flexible pipe . What darcy friction factor to use to take into account the carcass geometry.
http://www.gates.com/index.cfm?location_id=3042
Is it a flexible pipe, is it a flexible hose, how does it calculate those results ?
Katmar Software - Engineering & Risk Analysis Software
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
I am talking of a flexible pipe used in the subsea oil and gas industry like this one http://www
The carcass profile is the problematic geometry here. I wanted to know if there is another way of calculating flexible pipe pressure drop than using an absolute roughness of ID/250 since like I said this leads to an ID-independent darcy friction factor.
In the link provided by SToneCold (thx btw), it seems a similar formula is used, i.e a formula that leads to an ID-independent darcy friction factor.
The closest geometry being the corrugated pipe, it seems corrugated pipe correlations should be used instead ...
So nobody can explain why the formula e=ID/250 for a flexible pipe is used?
(http://www
However I'm sure that it wouldn't be the first time that an error was propagated time and time again, especially across the internet.
