Wind Loads...Bldg with Parapet Wall
What is considered the ridge height and eave height on a building with a parapet wall?
I have a building with a monoslope roof. Parapet is 5ft on the low side and 3 ft on the high side.
The actual frame has a low eave height of 52ft and max height on the high side of the monoslope of 55ft.
ASCE 7-05
What is the ridge and eave height considered to be?
ASCE 7-05
RE: Wind Loads...Bldg with Parapet Wall
After all, even for the latest revision, we are talking about an estimated projection of winds over the next 50 years, rounded to the nearest convenient 5 or 10 mph increment, based on fewer than 500 weather stations nationwide, some of which had as little as 5 years of historical wind records. And we almost all get the same non-hurricane wind speed.
