current transformers
which side should p1 face on a ct toward the bus bar or away from the bus bar ? 2/ would you short out ct secondaries when pressure testing ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: current transformers
#2 If in doubt, short it out. :) Only 1 short is required per each multi ratio ct (X1-X5)
