API Type for Vertical Submersible/Turbine/Submerged Pump
Can someone please tell me if there is any difference between Vertical Submersible Pump and Vertical Submerged pump? Is it like Submersible pump has the whole assembly including the motor assembly submerged while it is different for submerged pump?
Also under what API types (VS1-VS7) are Vertical Submersible, Vertical Turbine and Vertical Submerged pumps available with vendors?
Sumit Das
