A tag was passed belonging to an object that could not be found...
NX7.5 windows 7 64 bit (happens on 7.5.3 and 7.5.4)
Sometimes when loading assemblies we get the following error:
Could not open (part)
The following files could not be loaded
causing this open to fail:
(part) - A tag was passed belonging to an object that could not be found
If this error pops up, the assembly will fail loading and NX reverts back to the File>Open dialogue.
So far I haven't been able to trace this to any specific cause. Sometimes, loading "Structure Only", then individually loading the components, allows the assembly to load, but this is obviously a pain.
Has anyone else encountered such an error, and been able to pinpoint its cause?  What's the solution, or how to avoid?
RE: A tag was passed belonging to an object that could not be found...
Call GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
