ANSI/API pump Seal plan combined in the same drawing
Dear Sir/Madam
1. Can we put the API Plan 53 and ANSI plan 7353 on the same drawing (please see the attached file)?
2. All instrument tag (TG, PG, LG) required for API plan 53 also fit in the ANSI plan 7353 ?
3. Canned motor pump seal plan drawing also required to show up in the P&ID legend?
Thank you very much.
RE: ANSI/API pump Seal plan combined in the same drawing
I does not understand your third question, please explain in detail.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
If you are using API pumps you will use API 682 last version plan.
Yes, will instrumentation you like according with suitable standard API or ANSI.Instrummentation for Seal Plan should be shown on P$ID drawings.
I hope this help.
