Torsional analysis
Torsional analysis
A w8x40 steel beam with a continuous 3/8" x 14" wide steel plate welded to the top flange, spanning 25.33', fixed at both ends into a masonry wall, with precast concrete roof planks bearing 8" from the beam center onto the steel top plate with a unifrom total dead and live load producing 920 PLF. Can this beam resist the torsion created by this eccentric load? What formula is needed to check this condition?
RE: Torsional analysis
http://www.eng-tips.com/viewthread.cfm?qid=243419
The greater the torsion the greater the fixity required at the masonry wall. The beam-to-wall connection will need a good look.
