inexpensive carbide or ceramic blanks
We have devices with ~ 1 inch blocks flying through pulverized coal laden air at ~ 4000 fpm.  The brazed tungsten carbide cloth cladding that lasts years in other areas wears away quickly in this application.
I'm looking for sources for crudely finished tungsten carbide blanks. Plates, blocks, bars or rods.
Any suggestions?
thanks
Dan T
RE: inexpensive carbide or ceramic blanks
We supply carbide at Carbide Processors
What you want is "as sintered" parts.  These are just the way they came out of the sintering furnace. No post sintering grinding.
If you're going to braze these parts in place you may need some post-sintering braze treatment.
You also need to select the right grade. As an example, a Cermet 2 grade gives extremely long life cutting man-made materials such as MDF, Corian, etc.  It is not a particularly good grade for sawmills because there is too much impact in sawmills. On the other hand  Super C grade gives 5 to 10 times the life of ordinary carbide in sawmills but it doesn't have the wear life that Cermet 2 does in man-made materials.
The grade you need depends on what kind of wear you are experiencing.  Currently I look at wear from about 17 different ways when I do a failure analysis.
Sometimes carbide wear is caused by micro-chipping which means you need a tougher grade. Sometimes it is caused by straight abrasion which means you need a harder grade. Sometimes it is a chemical or electrochemical process in which case an alloy binder can make a huge improvement.
We deal with a couple dozen carbide suppliers around the world and each has its own personality. Some are much more expensive than others, some have much faster delivery, many have their own special grades and many have their own specialties.
If you want some help with this project, feel free to contact me.
Tom Walz
Carbide Processors, Inc.
Thomas J. Walz
www.carbideprocessors.com
Good engineering starts with a Grainger Catalog.
