Coupled Thermal-Structural, using LDREAD
Hi - have been trying to get a couple thermal-structural model working, using the LDREAD command. Everything seems to be going OK, except...
When I go to read and plot results I always get the error
"An error occured while attempting to open the results file FILE.rst"
(The .rth file is being updated everytime I run, I checked this).
I have read through the ANSYS coupled-field analysis guide section 2.5, various posts on this forum but nothing seems to be helping so far...
I am using physics environments, and the element type is correctly changing between analyses.
I'm doing a transient thermal anaylsis and then I want to input these temperatures into a structural analysis.
Excluding the structural solution phase everything works fine.
!first do the transient thermal analysis
/SOLU
ANTYPE,TRAN
PHYSICS,READ,THERMAL
OUTRES,ALL,ALL
ESEL,S,TYPE,,1
BFE,ALL,HGEN,,%INPUT%
KBC,1
TIME,5
DELTIM,20E-3,20E-4,20E-2
ALLSEL
SOLVE
FINISH
!secondly do the structural solution
/SOLU
ANTYPE,TRAN
PHYSICS,READ,STRUCT
OUTRES,ALL,ALL
ESEL,S,TYPE,,1
KBC,1
TIME,5
LDREAD,TEMP,,,,,FILE,RTH
TREF,0
ALLSEL
SOLVE
FINISH
Is anyone able to give any ideas as to what may be going wrong?
Any comments much appreciated.
HVSmith
CODE
/SOLU
ANTYPE,TRAN
OUTRES,ALL,ALL
ESEL,S,TYPE,,1
KBC,1
TIME,5
ALLSEL
SOLVE
FINISH
/SOLU
ANTYPE,TRAN
PHYSICS,READ,STRUCT
OUTRES,ALL,ALL
ESEL,S,TYPE,,1
KBC,1
TIME,5
TREF,0
ALLSEL
SOLVE
FINISH
HVSmith
RE: Coupled Thermal-Structural, using LDREAD
I've read and re-read the coupled-field analysis guide and from what I understand the code in the above post should be working...it's just never making the structural results file.
I'm also getting an error, on occasion, to do with an unconstrained model:
*** ERROR *** CP = 255.844 TIME= 12:04:52
A small negative equation solver pivot term has been encountered at the
ROTX degree of freedom of node 322. Check for an insufficiently
constrained model.
I've never worked with load-transfer coupled-field analysis before but it is certainly proving problemous to me.
Thanks for any advice you are able to give!
HVSmith
