STEEL CONNECTIONS MODELLING
Hi everybody!
I want to model many steel connections in Femap, but every connection needs a lot of time to design it (Bolts, endplates, holes etc). Does anyone knows, if there is a design program, that you can model easy any connection you want, and then export it as a 3D Solid model, so that you can import it to Femap and just define the connectors and the mesh??? All the programs I know for steel connections (ECPraxis, Steel connections for Sofistik etc) they only export plan views but not 3D Solid models.
Thanks!
RE: STEEL CONNECTIONS MODELLING
I've never the words
easy
connections
fea
mentioned in the same sentence.
tg
