Minimum moments in concrete column design
For the design of slender columns for minimum moment, does anyone see the need to use a M*1/M*2 ratio of -1 (constant moment in single curvature) for the calculations of the moment magnifier. I think it should be possible to design for the minimum moment but use a M*1/M*2 ratio of 0.
Majority of these columns are interior-braced columns so lateral moments and gravity moments are not governing the design. Exterior columns will be governed by gravity moments.
What are others people's opinion on this?
RE: Minimum moments in concrete column design
Dik
