What is defference beween SA and A?
Dear all, we can see some material as A 106, SA 106.
Please send me the explain why we have the defference beween SA and A?
what does SA mean? and A also?
Thanks you so much
Thanks you so much
RE: What is defference beween SA and A?
There are cases where the SA requires something that is optional in the A spec.
And then there is simply the time lag from ASTM revision to ASME adoption.
If you look in the header of an ASME spec it will say 'identical to ASTM xxxxx' and tell you what spec it was adopted from. If there are changes or exceptions they will be noted.
Plymouth Tube
SA means the ASTM Material Specification has been approved for use by ASME B&PV Code committee.
(Sorry to be pedantic, but doing things right usually requires no more effort than doing them wrong.)
