Solidworks Toolbox: New hardware item, Custom Property - Length
I have been searching and searching for a way to 'link' a custom property to the dimension named 'length' on the part I have added to the toolbox.
I've created a new level-3 folder under BSI --> Timber --> Structural. I have named a dimension "length" in the part.
In the toolbox configuration options 2 - Customise Hardware, I created a Custom Property called Length of type Textbox.
How do I 'link' this Custom Property value to the length dimension so when I drop the hardware item into the assembly, I can enter the length dimension and it set the correct dimension?
Any pointers would be gratefully recieved.
Many thanks
W
P.S. Solidworks 2009
Many thanks
W
RE: Solidworks Toolbox: New hardware item, Custom Property - Length
Check out YouTube: ht
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
Thanks for your reply. I've read up on smart components, but this seems for an assembly.
I suppose what I am trying to recreate is the length property similar to the structural steel toolbox component.
Any other ideas?
Many thanks.
