Edit sketch for revolve
Long time ago I mad a sketch witch I used for a revolve feature. However, now I have to edit/adapt the sketch because the form of my revolved part must be changed. I opened the sketch with edit and removed some lines of the sketch with trim and closed the curves with extend. I closed the sketcher and I get an error message (Update failure message is: Gaps in string or multiple loops.) that NX (7.5) can't make the revolve any more. If I look again to the sketched lines, I see that some lines that I removed in the sketch are still there. So my curves are not closed any more. However, if I open the sketch again, these line are really removed. How can I solve this? I think that some lines are still kept in the revolve feature which I removed in the sketch.
RE: Edit sketch for revolve
While in the sketch select edit... edit defining section and remove the old lines.
This is from an NX5 point of view. I hope this can be repaired at some point. Clearly not in NX7.5 oh well.
