can you disable dragging of draw elements?
Often when I am picking multiple draw elements, I inadvertently drag one, and it jumps to a new location.  Then I have to back up and start all over again.  Is there a way to disable the dragging of draw elements?
RE: can you disable dragging of draw elements?
Select one or more elements, RMB, Selected Objects, Fix.
Elements will turn green, and will not move.
Harold G. Morgan
CATIA, QA, CNC & CMM Programmer
Options:Drafting>Geometry>
uncheck the box for: Allow direct manipulation
Weavedreamer,
Brilliant!
Thank You!
