Title of column Help me?
hi
I want to change title of column to my language ( ex : Task name to Tencv, Duration to Tgian... )
Best regards,
RE: Title of column Help me?
Normally, this should be done by the language setting in Windows.
You're best bet will be to create a macro that renames the titles of the columns, although any changes or additions will need to be manually changed.
You can then save the sheet as a template for later use.
TTFN
