Hing Conncetion
Hing Conncetion
Hello
I want to model the frame below in ANSYS, my problem is modeling the connections between elements.
I used BEAM3 for element type which default connection type between two elements is rigid.
As you see the middle connection has three elements joined.
My aim is the connection between 1 & 2 be rigid and 3 be hinged.
How can I model it?
Can I use CP (Coupling feature)?
http ://www.fre e-imagehos ting.com/o ut.php/i94 12_12s.jpg
Best Regards
Pooyan
How can I model it?
http
Best Regards
Pooyan
RE: Hing Conncetion
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
RE: Hing Conncetion
