NX8 error - "Not aPart file
Hello everyone,
I am a new forum member and I am having a problem with Unigraphics NX 8. how to open UG files in Nx viewier. tell me about the convertion. I send the file. Maybe someone can open it.
Best regards
Artur
RE: NX8 error - "Not aPart file
When trying to open a file in NX
Let me start over:
WHERE DID YOU GET THIS FILE?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
I got it from my company. We worked there just to nx8. On the home computer does not work. Please help
Do you have the student/educational version of NX8 at home?
Where did you get the license file for NX8 for your home computer from?
Ben Loosli
I have versions of the Licence for students. Someone will help me?
You can't mix parts from the Student version with full NX.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I have given this file a friend who also has full versions of the program and can not open this file
Are you saying that this file was created using a full version of NX?  If so, what version?
John R. Baker, P.E.
Industry Sector
Cypress, CA
that comes with the full version NX8 of my work. wants to open a file to complete the project but I can not.
May I suggest that you call GTAC so that someone can walk through your 'workflow' step by step and see what exactly it is that you're attempting to do.
But I must warn you, if this involves trying to move parts from a full version of NX to a Student version and back, you will not get much help.
John R. Baker, P.E.
Industry Sector
Cypress, CA
If you only have NX7/7.5 student version at home, you cannot open a NX8 file. Plus, like John said, the student version cannot open a full version file.
Ben Loosli
Can someone opened this file?
ok thanks
I tried opening it and was not able to.  As far as NX is concerned, this appears to be a 'foreign' file.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I too heard of this issue, solution is open this either in higher version or new version in which that file is created.
Ex: created in NX3.5.2.5, Unable to open, then go with new NX version
Sorry, but if it were a newer version the error message would indicate that that was the problem.  Besides, I tried opening it in NX 8.0, the latest version of NX (and I've got an 18 year old UG part file which I can open just fine).
John R. Baker, P.E.
Industry Sector
Cypress, CA
The file does not open in Wildfire 4/5, either.
Ben Loosli
.prt is also used in CadKey and possibly ProE.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
