Revisting the collar tie calc using trig
thread507-285010: ceilinlg joist as collar tie
BAretired,
In referencing the "tie-force" .pdf you attached to the original referenced thread, I have a question.
When I look at it using trig, method of joints I think it is, I get a different value for T, which was my original "mistake" of twice the force you calculated. Knowing R = 1066 lb and the angle at A = 18.5 deg, I get T = 3185 lb. This comes from ABx = AB cos 18.5 = T, ABy = 1066 = AB sin 18.5, AB = 1066 / sin 18.5 = 3359, ABx = T = 3359 cos 18.5 = 3185.
The numbers above correspond with using L = 13.33 and h = 2.25 in your pdf, which gives T = 1579. I'm wondering where the error is.
BAretired,
RE: Revisting the collar tie calc using trig
