pattern along curve
pattern along curve
Sorry for my stupid question, but I found a (complicated) solution and I need some suggestions.
I'd like to create some holes along a 2D curve. In the sketcher I found only an Equidistant Points, but I want to set an 'easy' spacing between my holes (e.g. 50mm). I could obtain that with Point Definition and Repeat Object After OK, but resulting points are included in a geometrical set. If I want to apply the User Pattern command to a sketch (e.g. a circle) along the set of points, I need them in a sketch form! I thought to project all points and include them in a sketch plane, but maybe you can help me to find a less complicated procedure.
Thanks for your attention.
RE: pattern along curve
Ciao!
P.
It does exactly what you want, check the doc.
To get desired spacing, click Equidistant Points icon,
click curve, then click end-point of curve.
Change option to Points and Spacing and enter you parameters...
There you go.
Problem is, the points are unconstrained and after creating them, I cannot find a way to change the distance (ie, make it parameterized) - if you wanted to change your 25mm to 30mm, as far as I know, you would have to recreate the points. Please correct me if I'm wrong.
But, if you're only looking to create points 25mm from one another (or any set distance), select Equidistant points, then the end point, then edit the spacing to whatever you want.
Kevin Irrer
Northville, MI USA
You can change the distance but not the instance count. Change the first point as the rest use this dimension * the number of point.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
I'm sorry, I'm not sure I can understand your reply.
Well, I can't change the number of points (instance count?). But I don't care about that, I'd like to create a set of points along a 2D curve with a parameterized distance: is that * concerning that? kirrer explained how I can choose different options for equidistant points but, when the set is created, I can't edit anymore (for instance, a double click on the points doesn't show the equidistant points panel, in order to change the spacing).
Thanks for your attention and your help.
You need to create these points in Generative Shape Design. Inside your sketch, right click over the curve and output feature. This will allow you to use the curve in 3D. If we look at my pic I uploaded I created Point.59 - Point.73 in a ordered geometric set (this does not matter if its an OGS or a geometric set) using the Points and Planes Repetition command in Generative Shape Design. The * I talked about was a multiplication sign. If you double pick on the first point only the point menu will come up. If you change the distance on curve from 25mm to 30mm all the points will be equally spaced at 30mm
Derek
Win XP64
Dell T7400 16GB Ram
It's a pity I can't change even the instance counting, I hoped to obtain the initial point settings panel with a simple double click on the points, in order to set e new spating and a new counting. I guess a macro is not the hardest thing in the universe, but I'm just a beginner and I have to learn a lot of things before
Thanks again.
Derek
Win XP64
Dell T7400 16GB Ram
