Post Machining on Heat Treated 420SS
Hello....We have a Ø.800 420SS metal injected molded part that is heat treated to RC48-52. It has a hub with a cast hole on each side of the part and that needs to be reamed to the final size. We press fit a Torlon journal. We brought the post machining in house and our machine shop is having fits. They are using solid carbide reamers but are not having much success. Is there another reamer material they should be using? Is there a specific machine speed they should be using? Should we first ream the part, then heat treat? I'm worried the heat treating will shrink the hub IDs and we'll have to machine again. Thanks.
RE: Post Machining on Heat Treated 420SS
http
When in doube, ask the parts.
