static analysis software
Hi everybody
Do you know any software, which can do the static analysis of simple structures?
(I mean to calculate the forces and moments on a structure, knowing the loading and the constraints)
Thanks in advance.
Thanks in advance.
RE: static analysis software
There may be simpler (read cheaper) programs to do this, depending on the complexity of your structures.
you could check out the General Engineering Programs part of this forum for more information
NX 7.5
Teamcenter 8
Also SolidWorks Motion (which uses the ADAMS kernel).
Shurely shome mishtake.
When I used ADAMS it was aimed purely at multibody dynamics, not static analysis of structures. I would have thought any of the bazillions of FE codes would do this job well enough.
- Steve
Dan
www.eltronresearch.com
Dan's Blog
A car weighs 2000 lbf. the centre of gravity is exactly on the centreline, and half way between the axles, which are symmetrical etc.
What is the vertical force on each of the 4 wheels?
Cheers
Greg Locock
complex structures/problems require FEA ... there are many programs available, designed for different applications (buildings, airplanes, mechanisms, ...)
The syntax is identical to that of ABAQUS, which is a top-notch FE package, capable of solving very complex, non-linear problems.
//signed//
Christopher K. Hubley
Mechanical Engineer
Sunpower Incorporated
Athens, Ohio
http://www.grapesoftware.mb.ca/grape5_003.htm
It's only truss members and beam elements (no shells AFAIK), but the variety of constraints is quite comprehensive (deflection/force/thermal).
Linear analysis only.
FREE! (but please register & make a donation).
Steven Fahey, CET
