How to rework curve continuity
see what I can learn...
I have parametric curve with multiple segments (from a projection), see attached jpg. What is way to rework the tangengency problem between this to segments without removing the parameters?
thanks/regards
RE: How to rework curve continuity
Nx7.5
thx
Hey JOHN; any suggestions?
reg.
Is this the result of 1 projected curve feature (2 curves/edges selected to project)? If so, have you tried out the join curve option (located in the "settings" section of the dialog box)?
thx cowski on reply,
my question is more how to handle the problem direct without losing the dependcy - not the workoround
If the imported curves are not continuous, there is nothing that can be done without taking some extra steps, such as joining them or modifying one curve so that it matches the other, but these require explicit actions on the part of the user.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
