brick - internal angles.
Hi.
I want to calculate the minimal internal angle of a 3D-brick ,resulting from a trilinear interpolation (http://paulbourke.net/miscellaneous/interpolation/), with the minimal computacional cost.
Of course, I can take for each node, a pair of vectors and calculate the angle between them (for example, using cosinus).
But is there any faster way to get the minimal interior angle.
My input are 8 vertices in 3D Space.
Thanks.
Thanks.
RE: brick - internal angles.
that's the best way imo. use numpy for better results, as calculating in py for every element in computationally intensive.
