How to selec only a part of a curve.
Hi.
I have a clue regarding selecting lines in ugs nx 7.5
As you can see in the picture, I want to select ony a part of a line. I have tried almost all the selection filter combinations, but no success.
Anyone have a clue?
Regards, Ivar.
RE: How to selec only a part of a curve.
OK, if you want to only select the section up to where the other line intersects it you will need to toggle ON the icon to the Right of the 'Curve Rule' item on the Selection Bar.  This icon is labeled 'Stop at Intersection'.  Just toggle it ON and then you you will only select the curve segment that you wish to.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
