NUMECA-Optimization of pump design
Hi every body
i have a question from one of the softwares of NUMECA, would you please kindly advise?
I am handling pump design and optimization project.
- I do the basic design step using CFTurbo.
- I do the analysis step using the FINE/Turbo (with the mesh
generated in Autogrid),
- I do the fitting process (Fitting the parametric design to my
own design impeller) using Autoblade and Fine/Design 3D
- Now I want to use the next step in Fine/Design 3D software for
optimization, names: AutoBlade_CFD_SCREENING.
in this step I have a problem as follows:
when I set the settings and press the start button, the solution
start, but this error occurs:
"DESIGN3D STOPPED DUE TO THE FOLLOWING ERROR
The IGG/Autogrid igg mesh file cannot be found. Here are some possible reasons : 1/ The IGG executable cannot be found. 2/ No license file/server found. 3/ The mesh generation process failed because : The IGG/AutoGrid template file is not appropriate for this geometry. The blade geometry is not appropriate ot the present IGG/AutoGrid template file The running process has been stopped"
would you please kindly advise me how to solve this?
