Mystery USA Pump Manufacturer
Hello All:
I am trying to find pump curves for the pump shown in the photo but am stumped as to who the manufacturer is.  Does anyone know who the "D Pumps" manufacturer is (see casting in photo)?  I have tried Dayton and Dover, but they don't seem to fit what I have.  It is a 3-5 year old endsuction centrifugal, 4 x 3-10" pump, but no nameplate.  It does have a few identifiers in the casting:
DT22234 CC
A 196.
4 x 3-10
Any help would be greatly appreciated.  This is for an emergency power plant fuel forwarding skid for a power plant that was recently destroyed by an explosion.
Thanks in advance,
doehl1
David
www.mavenpower.com
RE: Mystery USA Pump Manufacturer
That would be a Durco Ansi pump; now a part of Flowserve Pumps. Should be very easy to find info and parts, just call the Flowserve distributor in your area.
I have some Durco Mark II in my plant, it does not look like Durco.
It seems a pump replicator for Goulds Pumps or other ANSI pump.
Where pump is located?
I would say that it's definitely a knock-off of a Durco, based on the picture.  Have a search for Summit Pumps model Clark 3 for a similar design.  Funny that the model given is A196, which is sort of a rip off of the Goulds 3196.
The A196 is a knockoff of the Goulds 3196 by Aardvark Pumps, whoever that is, but your picture shows a knockoff of a Durco, so it's possible that it's also by Aardvark.  At any rate, any 4x3-10 (or 3x4-10, depending on who you talk to) will be a dimensional replacement.
TenPenny is right; it is an Aardvark A196 Durco knockoff; Google it and see. Good job TP.
So used to that "D" logo I didn't catch the word "pumps" inside the Durco D on your bearing housing. A real Durco says "DURCO" inside the D; maybe now they say Flowserve.
WOuld like to know how well this pump is holding up and if it is in a tough service. If you are having trouble and need to replace significant parts, you may be better off replacing the whole thing with a real pump; i.e. Durco or Goulds.
As TenPenny says, since ANSI is a "dimensional" specification, a real Durco would be a drop-in replacement. As far as footprint, nozzle centerlines, and shaft centerline and length, a 4x3x10ANSI is a 4x3x10ANSI no matter whose pump it is.
Well job guys,
So now there is more options for findings performance curves.
-Contact Aardvark Pumps for your actual performance curves.
-Change barepump from Flowserve or Goulds could be an option. Both have ANSI pump, Flowserve has close impeller ANSI pump, Goulds open impeller ANSI pump, so they have a little different behavior between them.
And then you will use new suitable performance curves.
-Uses performance curves from similar ANSI pumps.
It could work with certain of error in case of emergency.
Thanks to all for your comments.  This pump is in service as a transfer pump for diesel fuel from main storage tanks to individual genset daytanks (35+ units). Pump has been in operation for about 3-4 years without any issues.  Somehow during the re-power effort, documentation on this pump skid didn't make it to me.  The Goulds knockoff rings true as I was told anecdotally that this unit was equivalent to a 3196 by a previous operations leader.
David
www.mavenpower.com
Dodgy pumps and no documentation supplied - such a frequent combination.  I am however impressed with the metallic blue paint job.
There is plenty of that metallic blue paint in China......
