Traceline Path Algorithm Failure
I'm currently using NX 7.5 and am trying to constrain a fairly simple model. When I move a certain part around or constrain it, I receive an error that says "The following error occurred during update: Traceline path algorithm failure." I tried googling it and found nothing. Any idea what this might be caused by and how to fix this?
Thanks!
RE: Traceline Path Algorithm Failure
Sounds like someone created an Exploded View.  Go to...
Assemblies -> Exploded Views -> Show Explosion
...and see if there are any exploded views in your file.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Yea that turned out to be the problem. I got rid of the trace lines associated with that part and everything is back to normal. Thanks John!
