Linking dimensions to Solidworks BOM
I am trying to Link Overall lengths, Widths, and heights to one column (just to show size of part). I'm sure this is simple, just looking for the right buttons.
Example:
DIMENSIONS
2.00 x 3.00 x 1.00
Example:
DIMENSIONS
2.00 x 3.00 x 1.00
RE: Linking dimensions to Solidworks BOM
Obviously, in a design table you can only bring one dim into one column. So if you want to have multiple dims in a column you have to create a formula such as =$a4 & "x" & $b4 & "x" & $c4. This formula can be assigned to a parameter column in the design table which can be imported into a BOM via custom properties.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
TOP
CSWP, BSSE
TOP
CSWP, BSSE
Online Help;
ht
TOP
CSWP, BSSE
"d1@sketch1" x "d2@sketch1" x "d1@extrude1"
That value is a column in the BOM.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
It will then be linked to your custom property.
Cheers,
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
