Is there an official document on acceptable crack tolerances...
Is there any official documents on what is an acceptable amount and size of cracks in residential foundation walls and floors. If so, could you forward a .DOC or .PDF or the like to me at DeveloperWatch@usa.com
I have a basement full of 1/4" cracks !!!
RE: Is there an official document on acceptable crack tolerances...
You have 1/4" cracks in your basement walls too? I guess it CMU/concrete block walls.
But, best to call a local structural engineer to review your situation and make some recommendations on repair etc.
Good luck.
I looked at a badly cracked residential basement wall recently. The workmanship was fine, but when they backfilled the wall they didn't brace it or have the floor framing in place. It was a disaster! The guy replaced a 1/3 of the basement wall and then turned around and did the same thing! The final result was to install a membrane waterpoofing system to prevent leaks.
