step file from Catia V5r19 to NX7.5
when i import a step file from catia it adds up to 5 extra numbers to my part number, why? i've tried saving the catia product file as a step, i've tried to create an all cat part and each time the part numbers match but i've got extra numbers after each. is there a setting i can change so it doesn't add additional numbers to my part number? i did not have this issue with nx5
RE: step file from Catia V5r19 to NX7.5
I really don't know much about Catia, but what I can tell you is that instead of transferring a STEP file you may want to utilize the NX to Catia translators.
that requires a license my company doesn't have.
whitch nx7.5 minor and patch are you runing
not sure i know what you mean by minor and patch. i'm on NX7.5.2.5
I'm guessing that you are 'importing' the step file using File -> Open... and filtering for step files. If that is the case, it is why you are seeing the odd file names. To avoid this you can create a new file (using the name you desire) and using File -> Import -> STEPXXX.... This workflow will import the step file into the new file you have created. Or, you can open the step file directly as you have been doing and simpy rename it when you are done.
Have you tried the external step translator from the windows nx7.5 programm group?
i normally use file>import>step203
using the translater function out of the start programs brought everything in with the correct naming convention.
i like the file import better but this will work.
thank you all
