[NX7] Fastener Assembly Configuration
why I don't see the Hole Type in the Fastener Assembly Configuration ?
Where is located the file or where must be ?
I find this file.
FastenerAssemblyConfiguration.krx
HoleFastenerMap.krx
ReuseLibraryFasteners.krx
Where in the customer default I can set the position if I want to position in a shared server folder for all my colleagues ?
Can my standard parts be used as NX Machinery Parts with all NX automations ?
I find poor documentation in the help.
Exist more documentation about ?
I find this file.
HoleFastenerMap.krx
Thank you...
Using NX 8 and TC8.3
RE: [NX7] Fastener Assembly Configuration
since nx 7.5 there is a customer default
Can you help me more ?
Using NX7 officially at the moment, and NX8 on test.
Thank you...
UGII_REUSE_LIBRARY_FASTENER_CONFIG=${UGII_MACHINERY_LIBRARY}\FastenerAssemblyConfiguration.krx
another way is to copy the config files from a nx share into the local usersprofile where they are located by default
but how have you found this variable ?
Because I need others two variables for hole...krx and etc...
Thank you...
Thank you...
some one was able to set Fastener Assembly function with owns parts.
This three files FastenerAssemblyConfiguration.krx, HoleFastenerMap.krx, ReuseLibraryFasteners.krx use NX Machine Library, but I want to use ours parts.
Documentation in NX7 is very, very poor.
Someone have some extra documents or krx file that I can use to manipulate to understand the right method ?
Thank you...
